Anonymous
Credit recovery with Virtual Channels enabled over ISL
I have credit recovery enabled on ISLs having Virtual Channels enabled.
But, I do see tim_txcrd_z errors being increased on ISLs.
Does credit recovery is supported in Virtual Channels???
Thanks for the help.
External Moderator
Re: Credit recovery with Virtual Channels enabled over ISL
In some circumstance, Credit Recovery not become active.
You can try to set QoS "portcfgqos" on OFF
BTW, in some case is suggested to set the Port "portcfgfillword" as idle instead ARB primitive
TechHelp24
Valued Contributor
Hi Rakesh,
Credit recovery is a feature used when a Credit is lost, the link is reset and thus all the credits are used again. Seeing an increase of tim_txcrd_z does not necesarily mean that a credit is lost, just that the flow control process is working.
Kind regards,
Felipon
