Anonymous
Connecting two logical switch by LongDistance SFP
[ Edited ]
In my case, the brocade 8gb san switch for hp bladesystem c-class is used and SFPs are long wave (longdistance).
i set different domain id for each san sw.
and running portcfgislmode enable.
and finally reboot but the state in both ports on San Switches is shown No_Light .
i am just fabric license and the distanse is nearly 1 KM.
is there any suggestion ?
Valued Contributor
Re: Connecting two logical switch by LongDistance SFP
Hi,
I have some questions for you, in order to try to figure out what could be going on:
What's in betweent the two switchs: just a monomode cable, what's the lenght? or is it xDWM, patch-panel?
why are you enabling islmode?
please paste the output of "sfpshow <port> -f" of the two ports you are trying to stablish a ISL with.
rgds,
Felipon
Anonymous
[ Edited ]
Hi ,
Thankyou So Much for helping.
(first Q : info about passive ) it is Patchpanel (SC Port) and singlemode cabe(LC-SC) .
the distance between SanSW1 to patchpanel is 30m and Sansw2 to patch panle is 10m. and two patchpanel  far near1KM from each other.
(Second Q : configuration) : just as the document and googling, i was not sure that enabling isl is required.
(Third Q : Output cli) : i run the command you said + Switchshow for more info below (in first Sansw SFP plugged in port 21 and second one on port 0 ) :
First SanSw :
swd77:admin> sfpshow 21 -f
Identifier: 3 SFP
Connector: 7 LC
Transceiver: 5401001200000000 200,400,800_MB/s SM lw Long_dist
Encoding: 1 8B10B
Baud Rate: 85 (units 100 megabaud)
Length 9u: 10 (units km)
Length 9u: 100 (units 100 meters)
Length 50u: 0 (units 10 meters)
Length 62.5u:0 (units 10 meters)
Length Cu: 0 (units 1 meter)
Vendor Name: HP-A BROCADE
Vendor OUI: 00:05:1e
Vendor PN: AJ717A
Vendor Rev: A
Wavelength: 1310 (units nm)
Options: 001a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max: 0
BR Min: 0
Serial No: UDA114
Date Code: 140127
DD Type: 0x68
Enh Options: 0xf0
Status/Ctrl: 0x22
Alarm flags[0,1] = 0x0, 0x0
Warn Flags[0,1] = 0x0, 0x0
Alarm Warn
low high low high
Temperature: 32 Centigrade -40 90 -10 85
Current: 32.022 mAmps 2.000 95.000 2.000 80.000
Voltage: 3296.6 mVolts 2700.0 3800.0 2970.0 3630.0
RX Power: -19.1 dBm (12.3 uW) 4.4 uW 2240.0 uW 11.2 uW 1122.0 uW
TX Power: -1.6 dBm (699.2 uW) 27.0 uW 2240.0 uW 67.0 uW 1122.0 uW
swd77:admin> switchshow
switchName: swd77
switchType: 72.3
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 3
switchId: fffc03
switchWwn: 10:00:00:05:33:93:8f:49
zoning: OFF
switchBeacon: OFF
switchName: swd77
switchType: 72.3
switchState: Online
switchMode: Native
switchDomain: 3
switchId: fffc03
zoning: OFF
switchBeacon: OFF
Index Port Address Media Speed State Proto
0 0 030000 -- N8 No_Module FC
1 1 030100 cu N8 Online FC F-Port
2 2 030200 cu N8 Online FC F-Port
3 3 030300 cu N8 Online FC F-Port
4 4 030400 cu N8 Online FC F-Port
5 5 030500 cu N8 Online FC F-Port
6 6 030600 cu N8 Online FC F-Port
7 7 030700 cu N8 Online FC F-Port
8 8 030800 cu N8 Online FC F-Port
9 9 030900 cu AN No_Sync FC Disabled (Persistent)
10 10 030a00 cu AN No_Sync FC Disabled (Persistent)
11 11 030b00 cu AN No_Sync FC Disabled (Persistent)
12 12 030c00 cu AN No_Sync FC Disabled (Persistent)
13 13 030d00 cu AN No_Sync FC Disabled (Persistent)
14 14 030e00 cu AN No_Sync FC Disabled (Persistent)
15 15 030f00 cu AN No_Sync FC Disabled (Persistent)
16 16 031000 cu AN No_Sync FC Disabled (Persistent)
17 17 031100 id N8 Online FC F-Port
18 18 031200 id N8 Online FC F-Port
19 19 031300 id N8 Online FC F-Port
20 20 031400 id N8 Online FC F-Port
21 21 031500 id N8 No_Light FC LE
22 22 031600 -- N8 No_Module FC
23 23 031700 -- N8 No_Module FC
Second SanSw :
swd77:admin> sfpshow 0 -f
Identifier: 3 SFP
Connector: 7 LC
Transceiver: 5401001200000000 2,4,8_Gbps SM lw Long_dist
Encoding: 1 8B10B
Vendor PN: AJ717A
Vendor Rev: A
BR Max: 0
BR Min: 0
Serial No: UDA114
Date Code: 140127
DD Type: 0x68
Enh Options: 0xf0
Status/Ctrl: 0x22
Alarm Warn
low high low high
Temperature: 29 Centigrade -40 90 -10 85
Current: 31.200 mAmps 2.000 95.000 2.000 80.000
Voltage: 3312.0 mVolts 2700.0 3800.0 2970.0 3630.0
RX Power: -19.3 dBm (11.7 uW) 4.4 uW 2240.0 uW 11.2 uW 1122.0 uW
TX Power: -1.5 dBm (711.7 uW)27.0 uW 2240.0 uW 67.0 uW 1122.0 uW
State transitions: 7
switchName: swd77
switchType: 72.3
switchState: Online
switchMode: Native
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:27:f8:bf:1e:e3
zoning: OFF
switchBeacon: OFF
0 0 010000 id N8 No_Light FC LE
1 1 010100 cu N8 Online FC F-Port
2 2 010200 cu N8 Online FC F-Port
3 3 010300 cu N8 Online FC F-Port
4 4 010400 cu N8 Online FC F-Port
5 5 010500 cu N8 Online FC F-Port
6 6 010600 cu N8 Online FC F-Port
7 7 010700 cu N8 Online FC F-Port
8 8 010800 cu N8 Online FC F-Port
9 9 010900 cu N8 Online FC F-Port
10 10 010a00 cu N8 Online FC F-Port
11 11 010b00 cu N8 Online FC F-Port
12 12 010c00 cu N8 Online FC F-Port
13 13 010d00 cu N8 Online FC F-Port
14 14 010e00 cu N8 Online FC F-Port
15 15 010f00 cu N8 Online FC F-Port
16 16 011000 cu N8 Online FC F-Port
17 17 011100 id N8 Online FC F-Port
18 18 011200 id N8 Online FC F-Port
19 19 011300 id N8 Online FC F-Port
20 20 011400 id N8 Online FC F-Port
21 21 011500 id N4 Online FC F-Port
22 22 011600 -- N8 No_Module FC
23 23 011700 -- N8 No_Module FC
Best regards
Valued Contributor
hi there,
sorry for my late response but I've been off for a week.
The RX signal is very poor and does not seem to be enough for the link to be stablished, there is a loss of more than 17dBm, which is a lot for the described environment. You should review the whole link in order to find which element is responsible of it (you can use a loopback plug in order to check the TX and RX signal levels in each point.
Rgds,
Felipon
