Anonymous
Connecting Brocade switches across buildings
I have two brocade islands in two sperate buildings (three blocks apart). I have one port in each brocade island connected to the brocade on the other building. The ports used for MirrorView. I have brocade 4900 switch on each end.
I want to connect another port on both islands and trunk both ports , so Mirrorview runs over those two ports instead of only one port..
External Moderator
Re: Connecting Brocade switches across buildings
---- I want to connect another port on both islands and trunk both ports , so Mirrorview runs over those two ports instead of only one port..
and how does it continue ? what is yours question ?
TechHelp24
Anonymous
My question is how to trunk the second port on each side with the first port already configured to run MirrorView.
External Moderator
Do you want to create a New Trunk, or add this New Port in the existing Active trunk ?
TechHelp24
Anonymous
Re: Connecting Brocade switches across buildingsI
I want to add new port to existing trunk.
External Moderator
Synopsis
portcfgtrunkport port mode
Description
Use this command to enable or disable trunking on a port. Use switchCfgTrunk to enable or disable
trunking on all ports of a switch.
When the command is executed to update the trunking configuration, the port to which the
configuration applies is disabled and subsequently re-enabled with the new trunking configuration.
Traffic through the ports may be temporarily disrupted.
Disabling trunking fails if a Trunk Area (TA) is enabled on the port. Use the portTrunkArea command
to remove the TA before disabling trunking.
TechHelp24
Anonymous
Hello,
Here is the output from trunkshow on one of teh switches.
Switch:admin> trunkshow
1:  0-> 39 20:00:00:05:2e:87:4e:a5   1 deskew 15 MASTER
I want to add port 40 to this trunk, is the following command looks right
Switch:admin> portcfgtrunkport 15/40 1
External Moderator
The best solution, you create a New 2 Port Trunk,after set as Active both site, remove the single Trunk.
When you add a second port to the active Trunk, you lost the connection.
TechHelp24
Anonymous
Intrrupting MirrorView for seconds won`t be an issue as long as it is going to come back up and resynchonize.. At this point , I want to get the exact mechanics to add port 40 to trunk group 1
Trunk Group is 1 , Master port is 0 ,  Domain 1
Do I replace slot number in portcfgtrunkport by Trunk Group number? as below
Switch:admin>  portcfgtrunkport 1/40  1
External Moderator
ups.. sorry please.
i had not read that with the mirror view.
yes, add the port to a active trunk is the simple way in this case.
TechHelp24
