Anonymous
Configuring ISL Between Two Fabrics
Hi All
I am planning to configure ISL between two fabrics.
Details:
Fabric 1: Two DS200B Switches with version v6.2.1b, both the switches are connected via ISL.
Fabric 2: Two DS300B Switches with version v7.0.1, both the switches are connected via ISL.
Can I configure ISL between Fabric 1 and Fabric 2.
Shailendra...
External Moderator
Re: Configuring ISL Between Two Fabrics
--->>>I am planning to configure ISL between two fabrics.
--->>>both the switches are connected via ISL.
sure you can ISL both Fabric, but keep in mind if you want to connect Fabric 1 with Fabric 2,at the end you have a Single Fabric, this is not a reccomende best Practices.
second, all switch in a ingle Fabric must have Unique Domain ID, and finally check with the Reklease Notes about FOS Compatibility.
TechHelp24
Anonymous
Hi TechHelp24,
Yes, I need to merge both the Fabrics and create one single Fabric. Also I want to retain all the zoning information which is present.
Is there any document available on the same. If yes please share.
