Anonymous
Compatiblity problem of Brocade 300 with AJ718 HP Transceiver
Hello every one I'm noob in Brocade and I have a problem.
My Brocade 300 can't suppoort Aj718 HP Transceiver.What can I do?Do I should  upgrade my 6.2 firmware?
Anonymous
Re: Compatiblity problem of Brocade 300 with AJ718 HP Transceiver
anyone??
please Help
External Moderator
AJ718 (A) is compatible and approved with Brocade.
what is the exact Error you get ? is the Port activated and Licensed ?
TechHelp24
Anonymous
My HBAs are not visible and switch ports are flashing amber.
but when I use Aj716a the HBAs are visible and my ports are green, and my VMs can see the storage LUNs.
But I have few numbers of Aj716,what should I do?
Anonymous
also my port is Licensed!
Anonymous
according to this link :
http://www.brocade.com/downloads/documents/QRG/brocade-hp-qrg.pdf
the above picture indicate that brocade 300 doesn't supports Aj718A
my question is that if I upgrade my firmware to 6.3 or 6.4, it will be OK?
External Moderator
Anonymous
this link only include brocade 4gb SAN switch
but I have brocade 300 8Gb SAN switch.
please tell me should I or should not upgrade my firmware??
External Moderator
URL Posted in preview post, indicate 8G SFP.
about FOS Upgrade, as fair as i remember, brocade closed such defect with non-branded Brocade SFP i believe with FOS 6.4.0 or 6.4.0a, DEFECT is listed in release Notes.
I dont have at the moment release notes on the hand, however you should be able to find it in Google or here in the community.
TechHelp24
Anonymous
Tnx.
finally I found it on HP site release note that it fixed on FOS 6.4.
I'm going to upgrade and I hope it will be ok.
