Occasional Contributor
Cascading HP 8/32 to Brocade 6510 switches
Hi
The customer currently have:
2 x 8 Gbps 32 ports switches with FOS v6.4.1 and
2 x 8 Gbps 32 ports switches with FOS v5.3.1.
They have purchased new 16 Gbps 6510 switches and I need to cascade them together. Is there a need to upgrade their FOS to the same version just so that the servers connected to their old switches and access the 3PAR array that is connected to the new switch? How many stages of upgrade do I need to go through if I want to put all of them to 7.4.X?
Thanks in advance.
Broadcom Moderator
Re: Cascading HP 8/32 to Brocade 6510 switches
Hi,
the new 6510 requires FOS from 7.0, and current target path (TP) is at 7.4 - was updated in April
https://www.brocade.com/content/dam/common/documents/content-types/target-path-selection-guide/brocade-fos-target-path.pdf
You cannot mix the FOS 5.3 switch with FOS 7.4, so these need to be upgraded to at least 6.x, I would put them on the same version as the other FOS 6.4 switches, at least. Or all switch on TP, 7.4.1e
FOS 5.3 -> FOS 6.0.1a -> FOS 6.1.2c -> FOS 6.2.2g -> FOS 6.3.2e -> FOS 6.4.1h -> FOS 7.0.2e -> FOS 7.1.1c  -> FOS 7.2.1g -> FOS 7.3.1e  -> FOS 7.4.1e
If you can take disruptive upgrades, then you can take two steps - for example skipping 7.2 and 6.3
Note
  • Upgrading to Fabric OS v6.2.2 is only allowed from Fabric OS v6.1.0 or later
  • 7.3.1e release notes say: Disruptive upgrade to FOS v7.3.1e from FOS v7.1 is supported.
  • Notice that for FOS 7.4.1e - Migrating from FOS v7.2 (7.4.1e RN)
    • Any 8G or 16G platform operating at FOS v7.2.x must be upgraded to FOS v7.3.x before upgrading to FOS v7.4.1e.
    • Disruptive upgrade to FOS v7.4.1e from FOS v7.2 is not supported
Former Brocadian
Hi there,
Please could you let me know the switch models in question.
FOS v5.x Is not supported so there is no ineroprability between 5.x and 7.4x - any working connection would be unsupported.
FOS 6.1e is the oldest FOS version that is included in the releases notes for v7.4.
The upgrade options would depend on the switches being used.
kind regards
Rick
Kind regards,
Rick
If my response has solved your query please click the "Accept as Solution" button.
All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider. .
Thanks Martin and Rick for responding.
I've confirmed that the customer's old switches are Brocade SilkWorm 4100. All 4 of them. In HP terms, it should be 4/32 instead of 8/32 I have incorrectly written in the subject heading.
I stand corrected. The 2 switches that are having FOS v v5.3.1 are Brocade SilkWorm 5000. Those two that have FOS v6.4.1 are Brocade SilkWorm 4100.
Former Brocadian
Hi,
thanks for the info,
As the switches are 4100, the highest FOS version they can run is FOS v6.4.3h.  So I believe this should be your target for the 4100s and this will connect with your 6510 running 7.4x.
kind regards
Rick Stephens
Kind regards,
Rick
Hi Rick
Does that meant that for both of the following:
FOS v5.3.1 in Brocade SilkWorm 5000.
FOS v6.4.1 in Brocade SilkWorm 4100
I just need to upgrade both to FOS v6.4.3h(as it is the highest FOS version these 4Gb/s switches can run) and I will have a supported ISL connection to the 6510 running 7.4.x?
Thanks.
Broadcom Moderator
Hello,
yes, that's correct. You need to upgrade both devices to FOS 6.4.3h to build an ISL between them and your 6510.
AG
