Anonymous
Can't connect to DS8100 after Firmware Upgrade 6.1.1d to 6.2.2b Brocade 4020
Hello,
I have a BladeCenter E with 2 IBM Brocade 20-Port 4GB SAN switch (32R1818= Brocade 4020), firmware level 6.1.1d, this switches are directly connected to a DS8100.
After firmware upgrade 6.1.1d to 6.2.2b, the switch was unable to see DS8100, I found that FICON is not supported at this firmware level (6.2.2b) so I did the downgrade to 6.1.1d.
Is there a specific firmware level supported for Brocade 4020 (32R1818) beyond 6.1.1d with FICON support? I read somewhere firmware level 6.3.x don't support Brocade 4020.
Any ideas??
Thanks in Advance
Super Contributor
Re: Can't connect to DS8100 after Firmware Upgrade 6.1.1d to 6.2.2b Brocade 4020
alan,
--->>> 6.1.1d with FICON
Generally FOS 6.1.1d is ( same 6.2.2b ) not for FICON Supported.
--->>> Is there a specific firmware level supported for Brocade 4020 (32R1818) beyond 6.1.1d with FICON support?
Yes, FOS 6.2.0e is FICON Supported Release.
And finaly, the definition "Supported" meant IBM Tested and Certified Certain FOS Release in FICON environment and Support this Specific Rel.
That they can't connect to DS8100 after Firmware Upgrade from 6.1.1d to 6.2.2b is the Error other Natur, but not in the 6.2.2b FOS release, because as mention both 6.1.1d and 6.2.2b are no FICON Supported.
If you are satisfied with the responses please mark as 'Answered'.
If not, just let me know I can see to get more info.
I would appreciated if you rate the threads.
Thank you.
Anonymous
Thanks ABBA-SYSTEMS,
This is Strange, switches are working fine with 6.1.1d and as you mention this release is not FICON supported.
So is better to upgrade to 6.2.0e instead of 6.2.2b?, is there a 6.3.x firmware release for Brocade 4020 with FICON support?
Thanks in advance.
Alan
Super Contributor
--->>> is there a 6.3.x firmware release for Brocade 4020 with FICON support?
No, 4020 is only support by 6.2.x, current Rel. is 6.2.2c (ut is unkown to me if this c rel. is FICON suppoted )
--->>> So is better to upgrade to 6.2.0e instead of 6.2.2b?
You can downgrade from 6.2.2d to 6.2.0e but not sure that solve the problem.
Thank you.
Anonymous
We did the downgrade to 6.1.1d as soons as we knew 6.2.2d wasn't working with FICON, so we have a open PMR with IBM, i will wait to they anser as wll, I think I'll try 6.2.0e and loow what happens.
Thanks a lot!
