Anonymous
CORE BLADE - DCX - can we use for host connections ?
Hi Guys.
we have 2 modules which are showing as CORE BLADEs , rightnow there is no single host connected to this but we have a requirement to use any available ports so can we use this module ports for host connections ?
Also why they are differentiate by SW BlADE TYPE ??
sansw06:administrator> slotshow
Slot   Blade Type     ID    Status
  1     SW BLADE     51     ENABLED
  2     SW BLADE     51     ENABLED
  3     SW BLADE     51     ENABLED
  4     SW BLADE     51     ENABLED
  5     CORE BLADE   52     ENABLED
  6     CP BLADE     50     ENABLED
  7     CP BLADE     50     ENABLED
  8     CORE BLADE   52     ENABLED
  9     SW BLADE     51     ENABLED
10     SW BLADE     51     ENABLED
11     UNKNOWN             VACANT
12     UNKNOWN             VACANT
416    8    0   ------   cu    8G   No_Sync     FC
417    8    1   ------   cu    8G   No_Sync     FC
418    8    2   ------   cu    8G   No_Sync     FC
419    8    3   ------   cu    8G   No_Sync     FC
420    8    4   ------   cu    8G   No_Sync     FC
421    8    5   ------   cu    8G   No_Sync     FC
422    8    6   ------   cu    8G   No_Sync     FC
423    8    7   ------   cu    8G   No_Sync     FC
424    8    8   ------   cu    8G   No_Sync     FC
425    8    9   ------   cu    8G   No_Sync     FC
426    8   10   ------   cu    8G   No_Sync     FC
427    8   11   ------   cu    8G   No_Sync     FC
Truncated..
thanks in advance.
External Moderator
Re: CORE BLADE - DCX - can we use for host connections ?
Core Blade cannot be used for host or storage connections, port on CB are intended only for ICL = Inter Chassis Link connectivity.
--->>>Also why they are differentiate by SW BlADE TYPE ??
Each Blade Type have different name and Blade ID, i.e. Switch Blade, Application Blade, etc.
for details refer Switch Types and Product Names
TechHelp24
