Anonymous
Buffer Credits calculation help required.
Hi All,
Sorry for my intrusion ... I have a question regarding our FiberChannel configuration where I need Your help. We have two sites (main and DR) which are connected by two distinct ways via two Brocade DS200B and DS300B FB switches (via dark fiber). At present, the distance between the sites is 11km (roughly 7 miles) and everything works as expected without issue.
However in the coming months we will be relocating to a new DR site and the distance will be tripling (35km - 22miles). We will be using new GBICs to accomodate for the longer distance. The question at hand is: Do we need to change the buffer credits for those ports to accomodate or not and if yes, to what value. I am not a FC/network guy so couldn't calculate the expected/needed value by reading the user guide of the switched. At the moment the buffer credits are on value 8.
I'm sure a FC specialist has the right tool/info at hand and can easily answer this.
Thanks,
Pascal
Valued Contributor
Re: Buffer Credits calculation help required.
Hi,
what is the current speed of the ISL?
and the current ISL configuration?
could you paste the output of portcfgshow <port>?
Depending on the current config, the buffers are automatically calculated and reserved or have to be configured manually.
rgds
Anonymous
Hi,
The current speed is 4GB and here is the requested output:
admin> portcfgshow 7
Area Number:              7
Speed Level:              AUTO
AL_PA Offset 13:          OFF
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             ON
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
Persistent Disable        OFF
NPIV capability           ON
QOS E_Port                OFF
In the webconsole I have additionally
Port Media lw
Port Type E-Port
Speed (GB/s) N4
F-Port BB Credit 8
Hope it says more to you than to me :-). Thanks
Valued Contributor
As per that output, the port does not have Long distance configured. If the distance is increased up to 35 Km you will need to activate this feature (which requires extended fabric license).
In order to configure configure the ISL, the command to use is portcfglongdistance. With this command you can modify the following settings of the port config:
Area Number:              7
Speed Level:              AUTO
Trunk Port                ON
Long Distance             OFF
VC Link Init              OFF
Locked L_Port             OFF
Locked G_Port             ON
Disabled E_Port           OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
NPIV capability           ON
QOS E_Port                OFF
Usually depending on the xWDM equipment, you have to set VC LINK INIT and/or R_RDY. But, a standar Extended ISL config would be the one shown in the following example:
ED48K_133:root> portcfglongdistance 10/14
Usage: portCfgLongDistance PortNumber       Distance_Level <VC Translation Link Init> <Desired Distance for LD mode>
distance_level:         L0  : normal
                        LE  : <= 10km
                        LD  : auto
                        LS  : static
vc_trans_link_init:     0   normal
                        1   VC translation
desired_distance:       in Kilo-meters
                        valid for LD or LS level only
Please enter the long distance level -- LS
Please enter the vc translation link init -- 1
Please enter the desired distance (in Km) -- 35
Reserved Buffers =        76
ED48K_133:root>
As you can see, when you insert the distance, the switch automatically calculates the required number of BB credits (I recommend you to set the speed manually to 4G in this case). the only issue is that the switch calculates the number of required BB credits based on maximun size frames, and usually the average frame size through the ISL is smaller, so you could increase the desired distance in order to get more BB credits.
Rgds,
Felipon
Anonymous
Thanks Felipon. This is already very helpful ...
New Contributor
Hi Felipon,
What about "vc_translation_link_init" Does this need to be set and what does it do for an extended fabric?
Also, if I don't perform QoS zoning should I disable QoS on this port?  What does having it enabled vs disabled on that port if no QoS zoning is in tact?
SW6520_MDC_FAB_A:FID128:admin> portcfglongdistance 95 LS 1 -distance 25
Reserved Buffers =        206
Warning: port (95) may be reserving more credits depending on port speed.
SW6520_MDC_FAB_A:FID128:admin> portcfgqos --enable 95
SW6520_MDC_FAB_A:FID128:admin> portcfgshow 95
Area Number: 95
Octet Speed Combo:        1(16G|8G|4G|2G)
Speed Level: AUTO(SW)
Trunk Port ON
Long Distance LS
VC Link Init ON
Desired Distance          25 Km
Reserved Buffers          220
Locked L_Port OFF
Locked G_Port ON
Disabled E_Port           OFF
Locked E_Port OFF
ISL R_RDY Mode            OFF
RSCN Suppressed           OFF
LOS TOV enable OFF
NPIV capability           ON
QOS Port ON
Port Auto Disable:        OFF
Rate Limit OFF
EX Port OFF
Mirror Port OFF
Credit Recovery           ON
F_Port Buffers            OFF
Fault Delay: 0(R_A_TOV)
NPIV PP Limit:            255
CSCTL mode: OFF
D-Port mode: OFF
D-Port over DWDM:         OFF
Compression: OFF
Encryption: OFF
FEC: ON
This is going directly over a "Dark Fiber" cable to another 6520 SAN Switch.
Matt
Valued Contributor
Hi Matt,
vc_translation_link_init sets the fillword used within the ISL. When '0' it uses IDLE primitives whilst when '1' it uses 'ARB'. Depending on the xWDM array, the speed of the link, you should use one or the other.
If QoS is not being used, keep it disabled. With long-distance ISLs there is not big difference, since there are no different VC assigned to the QoS zones.
Kind rgds,
Felipon
External Moderator
pascal,
"portbuffercalc" command help you to calculated required buffer credit.
or see this Article written by Dr. Steve Guendert
http://community.brocade.com/community/blogs/mainframe/blog/2013/02/27/buffer-credits-and-frame-size-calculation-in-fos-71
TechHelp24
