Anonymous
Brocade zoning
Hi,
I'm new in Brocade zoning, I have 2 Brocade 10 8Gb FC switches in a IBM BladeCenter E. I have 3 servers HS22 in this BladeCenter. I connected a storage IBM V7000 on these Brocade fabrics. Each controller of V7000 is connected to one Brocade fabric through 2 FC cables.
All of hosts should access to the same volumes located in the storage.
I need help to create aliases, zones to be able to connect my 3 hosts to this storage via my 2 Brocades.
In eache Fabric, I created these aliases and mapped their WWN, each host has one WWN and the storage has 2 WWN:
host1_a
host2_a
host3_a
v7000_a
v7000_b
My question: should I map the alias to the WWN located under Ports or WWN parent?
Are these aliases correct and enough?
I created these zones:
zone1 :   host1_a, v7000_a, v7000_b
zone2 :    host2_a, v7000_a, v7000_b
zone3 :    host3_a, v7000_a, v7000_b
Are these zones correct?
I create one config containing :
zone1, zone2 and zone3 and I enabled it.
I need your help, thanks a lot in advance.
Abbas
Frequent Contributor
Re: Brocade zoning
Hi Abbas,
Yes, the WWPN (WWN of the port) should be used. For more info about how to zone in a V7000 environment, please have a look at the zoning rules in the V7000 infocenter:
http://pic.dhe.ibm.com/infocenter/storwize/ic/index.jsp?topic=%2Fcom.ibm.storwize.v7000.doc%2Fsvc_configrulessummary_02171530.html
