Turn on suggestions
Showing results for
10-09-2012 04:59 PM
Hi there
This is my first post on this forum so please pardon if I have posted it in the wrong place. I am facing an issue which I have tried to look everywhere for without any success. I have a setup where there are two switches in each datacentre. They are about 2 Kms apart. I am trying to get HP EVAs to replicate over a dark fibre link (CWDM). There are no ISLs and the only connection between the switches are the CWDM links. The CWDM links that terminate on the switch ports produces green link lights, which will suggest to me that the links are working. However, when I login to the switches, the actual ports cannot see any WWPNs. I have never worked with CWDM before, so my questions are:
Any help will be greatly appreciated, so will be any documentation provided in this regard.
Thanks in advance.
Regards
10-09-2012 10:30 PM
Dipan,
you shuld first check compatibility between Brocade ( Switch Type, FOS Release ? ) and CWDM ( Model Manuf. ? )
Are both Switch Local and Remote correct configured ? i.e. Domain ID.
If yes, is the Fabric formed, with other word, is Switch_Local and Switch_Remote visible in the Fabric ?
10-10-2012 04:13 AM
Hi,
A diagram with environment would help us to understand the issue. Please, execute the commands 'fabricshow', 'islshow', 'switchshow', to show what is the switchs currently seeing.
10-11-2012 05:24 PM
Hi TechHelp24 and Felipon
Thanks a lot for your response.
@Antonio Bongiorno TechHelp24 the compatibility between the switches are fine. All the 4 switches have the same domain ID. Does that need to be changed? If so how, the switches at the same site will have the same domain ID or the switches forming the same fabric will have the same domain ID? Also I am not quite familiar with Switch_local and Switch_remote concepts, however even on the CWDM link that is working, one switch cannot see the other switch but the link light is green on both switch ports. This is what made me wonder in the first place if there are any special config required on the switch ports for CWDM links.
@Felipon, I have attached a file to the post, you can have a look and let me know if this clears things up. If it doesn't let me know what I need to do further and I can definitely do that. Please note that it is the 1511 and 1531 nm links that I am working on.
Thank you so much again for the help. I was not able to respond yesterday, apologies for that.
Regards,
10-17-2012 08:36 PM
Hi TechHelp,
Any updates on this please?
Regards,
10-17-2012 08:37 PM
Hi Felipon,
Regards,
10-18-2012 07:07 AM
Hi,
A green light in the port just means that there is connectivity between the cwdm and the switch.
In order to merge each pair of switchs into the same fabric, you need to assign a different Domain ID to any switch in the fabric. The procedure to do it is simple, but offline (and can affect port zoning and some host types):
SWITCH:root> switchdisable
SWITCH:root> configure
Configure...
Fabric parameters (yes, y, no, n): y
Domain: (1..239) 2
WARNING: The domain ID will be changed. The port level zoning may be affected
SW04_48K:root> switchenable
On the other hand, I asked in a previous post for the output of different commands: islshow, fabric, switchshow.
Rgds
10-21-2012 06:53 PM
Hi Felipon
Thanks once again for your response. Please find the files attached.
Couple of questions:
I thank you once again for helping me out. I hope my questions are not as stupid as I think they are. If you need any more outputs, please let me know.
Thanks and have a good day.
Regards
10-21-2012 09:44 PM
First to avoid some confusion about Domain ID:
Each Switch in the Fabric -no matter if the Fabric is formed as simple ISL or trough xWDM -
must have a Unique Domain ID.
Second, SAN Configuration PDF show the Brocade 300 connected to WDM,
WDM show as be configured with 15xx SFP.
Question: What type of SFP are inserted into Brocade 300 ? is not clearly enough.
I suspect you have some configuration mismatch in Component and Switch config itself.
10-22-2012 02:32 AM
Hi,
On the one hand, you need to modify the Domain ID, so that it is unique fabricwide.
On the other hand, as @Antonio Bongiorno TechHelp24 posted, there must be a compatibility/configuration issue. According to the logs attached, the SFP used on port 15 are not compatible/detected by the switchs.
switchName: gbbnepfs01
Index Port Address Media Speed State Proto
15 15 010800 -- N8 No_Module FC
switchName: gbbdrpfs02
switchName: gbbnepfs02
15 15 010800 id N8 Mod_Inv FC "Speed Mismatch / Incompatible Vendor"
switchName: gbbdrpfs01
15 15 010f00 -- N8 No_Module FC
Take a look at the CWDM array specification in order to see what kind of SFP is required in the switch. Bear in mind that Brocade switchs need to use Brocade SFPs.
rgds
