Turn on suggestions
Showing results for
10-27-2016 12:08 PM
Hi Team
we are having an issue with memory which is more than 75%. I have checked memory by using the memshow.
I see the output and calculated it is 80% full how can I clear the space on the switch is there any way or else I need to check with support?
Thanks
Ravi Pendli
10-27-2016 09:51 PM
by 75% you are in range, however i would suggest you to specified a bit more.
switch type / model, FOS release
similarly behavior was closed in the past as Defect on diverse FOS Release.
10-27-2016 11:35 PM
A hafailover/hareboot, depending on the platform, always helped here.
I would open a case with support anyway to have them check if any process(es) have misbehaved.
11-02-2016 07:13 AM
Hi , you may clean up the switch by using the command "supportsave -R"
which deletes the coredumps and datarubbish on the switch
rgds Michael
