Turn on suggestions
Showing results for
06-08-2011 02:39 AM
I have to upgrade Brocade 4900 firmware from 6.1.1a to 6.4.0c. whats the upgrade path suggested. Can it be done online?
06-08-2011 03:26 AM
6.2.2e > 6.3.2b > 6.4.0c
The upgrade can be performed online but do upgrade one fabric at a time.
06-08-2011 07:48 PM
Hi suraj
You can use DCFM to do your Fabric OS upgrade is makes the job a lot easier.
Good luck
Cheers
David
