New Contributor
Brocade san 24b5 2498 ethernet management port is down
[ Edited ]
Hi, I've got 2 Brocade san 24b5 2498 that were previously configured through Fabric Manager.
Then, we changed their location in rack (just moved some units down) and I've figured out that one of management ports is always down.  It is availiable only through console and works perfect, except I cannot connect through Fabric Manager. I'm not a pro in using CLI, so I'd like to return it back.
What i've tried:
  • Reboot
  • Connect with working patch cord from another switch
  • Tried to reconfigure negotiation speed for network port from console
Nothing mentioned above helped. All suggestions would be greatly appreciated!
Broadcom Moderator
Re: Brocade san 24b5 2498 ethernet management port is down
Hello,
Does physical layer on the Ethernet port is up?
You can see it with CLI command: mii-tool -vvv
Sample output of CLI command: mii-tool -vvv
eth0: negotiated, link ok
registers for MII PHY 28:
1140 796d 0020 60c1 01e1 c801 000d 2001
4024 0200 3800 0000 0000 0000 0000 3000
0000 0f00 0000 0000 0000 0000 0000 0000
0400 871c 0000 ffff 0000 2378 0000 0000
product info: vendor 00:08:18, model 524 rev 1
basic mode: autonegotiation enabled
basic status: autonegotiation complete, link ok
capabilities: 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD
advertising: 100baseTx-FD 100baseTx-HD 10baseT-FD 10baseT-HD
If physical layer is up and link ok, make sure both end are connect to AN or Full Duplex, then check if you can ping the IP address of the switch from the first gateway and that gateway in on the same network.
New Contributor
admin> mii-tool -vvv
rbash: mii-tool: command not found
Maybe there is another one I could use? I found only command list  by link below, but it doesn't seem to give me a catch right away.
http://community.brocade.com/t5/Fibre-Channel-SAN/Brocade-commands/ta-p/2263
Broadcom Moderator
Hello,
This command need to be running in root mode.
New Contributor
Hi, tzimmerm
Sorry for not replying for a long time. My colleague prepared switch for a first use and couldn't remember root password. I'm going to reset it in a few days, hope it solves my problem.
Broadcom Moderator
Hi Serge,
The ifmodeshow CLI (admin level) also displays ethernet connection status, though less detailed than mii-tool. Further, to look at the IP setting / configuration, you can use the 'ipaddrshow' command.
switch:admin> ifmodeshow eth0
Link mode: negotiated 100baseTx-HD, link ok
MAC Address: 00:60:69:D0:24:40
