Anonymous
Brocade recommended firmware levels
Hi All,
        Could some one help me with the recommended firmware levels for the below mentioned hardware. Thanks in advance.
Brocade 39004.4.0b
Brocade 39004.4.0
Brocade 39003.1.1c
Brocade 3800/ VL3.2.0
Brocade 28002.6.2c
Brocade 2005-H165.0.1b
Brocade 2005-H163.2.1b
Brocade 2005-H085.1.0d
Brocade 2005-B325.3.0c
External Moderator
Re: Brocade recommended firmware levels
3900 is supported by 4.x and 5.x  FabOS 3.x is not supported by 3900
2005-H16 ( IBM label ) is Genuine Brocade 3850, same FabOS support the 3900 as mentioned and is not support by any 3.x
2005-B32 ( IBM label ) is Genuine Brocade 4100, support FabOS 4.4.x , 5.x and 6.x
TechHelp24
Anonymous
Hello Tech,
        Thanks a lot for your quick response. It was of great help to me. I also happened to see your picture under featured members column in the home page. Nice to see your reply. Thanks again.
Anonymous
Where do you find the supported firmware levels for the different san switches?
I have a 3800 running v3.1.2a that I need to ISL to a new  IBM 2498 / Brocade 24port running v6.1.1a
External Moderator
In the Release note is attached.
BTW. Next create a new threads.
TechHelp24
Anonymous
On our McData 6140 directors, we are currently at firmware version 09.06.02 4. Is this the same as 9.6.2? What is the latest firmware release for this switch?
External Moderator
Jmiller1,
can you please create a new threads ?
TechHelp24
