Anonymous
Brocade & McData Fibre Switch interconnectivity.
All,
Help?.
We have a "problem" with some Brocade fibre switches and connecting them to our existing McData Sepheron 4500 switches that are connected to our Hitachi Thunder 9570 SAN.
The Scenario:
IBM Blade array 8677 with a pair of Brocade 10port Fibre switches.
These are required to connect to our McData 4500 switches to allow the IBM Servers to use SAN space on the Hitachi SAN.
I understand there is an "access gateway mode" that can be used to this job, however our McData switches aren't on EOS 9.6 and don't currently have NPIV capability.
In the Brocade switch management there is a section for "EX-port", however this section is greyed out and cannot be selected.
Can anyone advise on the best way to get these two switches to talk to each other?
Or if we're missing something obviously.
McData Sepheron 4500 Switch:
Type Number: 004500
Model Number: 001
Serial Number: T2014363
EC Level: 1040428
Firmware: 09.02.01 1
Brocade IBM Blade Module
Manuf Serial Number: TV040029148
Supplier Serial Number: YK10UZ8S5001
Firmware: 5.3.1
Cheers
PeterP.
External Moderator
Re: Brocade & McData Fibre Switch interconnectivity.
Peter,
the best way upgrade the McDATA to 9.6.x , i don't think you can connect the Brocade Blade in AG Mode to a McDATA w/o NPIV.
If you Upgrade the McDATA to 9.7.x you must upgrade the Brocade to 6.0 or higher.
TechHelp24
TechHelp24
Anonymous
TechHelp24,
Cheers for the info.
do you know what the EX-port section is? and why it could be greyed out on our switches.
Licensing issue maybe?
Cheers
PeterP
External Moderator
Peter,
EX_Port is The type of E_Port used to connect a Multiprotocol Router to an edge fabric.
An EX_Port follows standard E_Port protocols and supports FC-NAT but does
not allow fabric merging across EX_Ports.
see attached PDF SAN Glossary
Port Color:
Green: Link Up
Black: Link Down
Red: Port Up but with error
Grey: Port Stopped ( can be caused by not Licensed Port )
Yellow: Port Started but Dusabled
to make sure is the Port is licensed, check the License onthe switch.
TechHelp24
TechHelp24
Anonymous
Hmm.
ok to clarify as I'm stil la little confused.
With the brocades in access gateway mode and NPIV enabled on the McData switches would the additional ports from the brocade switch appear in the console of the McData switches? enabling port zoning as if it is one large switch?
Will Ex-Port usage give us this?.
Or will using Ex-port usage mean that all the Brocade ports will appear to come though the interconnected port?
Sorry to be a pain..
PeterP.
External Moderator
Peter,
EX_Port is not supportet in AG Mode.
EX_Port is only Avilable in FabOS Native Mode, see FOS Admin Guide for exact details About EX Port, or in the Glossary.
You can connect the Blade Switch ( or other switch in Example 200E or 300 ) in AG Mode only trough / to NPIV.
TechHelp24
TechHelp24
