Occasional Contributor
Accepted Solution
Brocade Switch monitoring
Hi,
which principal counters can we monitor on a brocade switch DS-6520B  ? And their thresholds ?
Thanks.
Best regards
Regular Contributor
Re: Brocade Switch monitoring
Hi,
it depends on the Firmwareversion and License you have.
Do you have the Fabric Vison lic?
Kind Regards
Ralf
Hi,
Thanks for the answer.
I just need to know  how to monitor the strategic counters and their tresholds for this brocade switch ??
If i can have links to special documents ?
firmware version is : Fabric OS:  v7.3.1d
we have not Fabric Vison lic.
Best regards
HI
We have Brocade 6520 96 port and 6505 24 port switches.
In order to interpret the thresholds of the counters returned by the SNMP graphs under Cacti, I want to know the max thresholds, min normal of these counters:
For example, the counters "RX words" and "TX words" ..... As well as "TX Frames" and "RX Frames"; "RX Bad EOFS"; "RX CRC Errors" ......
Kernel:            2.6.14.2
Fabric OS:      v7.3.1d
Best Regards
External Moderator
@abdelaziz.maatallah
for RX and TX both words and frames, the max counter is
max 10 digit = 9999999999 and min one digit = 0
for --->>>"RX Bad EOFS"; "RX CRC Errors"
i believe ???  the same 0 and the max. value can reached the same = 10 digit
TechHelp24
Hi
Thank you Antonio, but I would like to know how these counters are measure ? Their  measure units (see attachement : Kb, Mb, u ...m )?
The current value displayed is such normal or not, when compare it with the theoretical threshold of these counters given by Brocade. Thanks if you have any official documentation that gives these explanations.
Best Regards
Broadcom Moderator
Hi,
it sounds to me that you are looking for Cacti/display related information.
Found this on the cacti forums:
10^-18  a - atto
10^-15  f - femto
10^-12  p - pico
10^-9   n - nano
10^-6   u - micro
10^-3   m - milli
0    (no unit)
10^3    k - kilo
10^6    M - mega
10^9    G - giga
10^12   T - tera
10^15   P - peta
Is that what you are looking for?
TL
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided solely as a convenience for Brocade customers. All systems and all networks are different and unique. If you have a service affecting network problem, please open a TAC service request for service through Brocade, or through your OEM equipment provider.
Hi Thomas
thanks for your reply.
It meets in part my need (with regard to counters units).
But I'm still waiting if anyone has an idea about Brocade theoretical thresholds (minimum ... normal .... maximum) for the measured values of these counters for each port ?? Is there a link for documentation ??
Best Regards
Former Brocadian
Hello @abdelaziz.maatallah
I noticed your last post has gone unanswered by the community. Based on your current contract with an OEM and our legal obligations, we cannot engage with you via a formal support channel (a.k.a. our TAC Engaged Program).
That being said, you've had some great feedback thus far and hopefully the Community or your OEM provider will come through for you on this one.
Please let us know if there is anything else we can do to help facilitate your case resolution.
Best Regards,
Denise K.
Brocade Community Team
@DeniseK
Hello @DeniseK
Thank you for your reply and thank you also to the community participants who responded. I did not get the desired answers but I hope the topic will interest others. I will also ask the question to our OEM provider.
Best Regards.
