Anonymous
Brocade Switch 3250 not booting
Hi,
I have a brocade silkwork switch 3250 which gives the following error.
The system is coming up .....
1. Start System
2. Recover password
3. Enter Command Shell
When giving the option one the following details I got
Option? 1
Booting "Manually selected OS" image.
Entry point at 0x00800000 ...
Linux/PPC load:
BootROM command line: quiet
Uncompressing Linux...done.
Now booting the kernel
ð
The system is coming up, please wait...
1) Start system.
2) Recover password.
3) Enter command shell.
When I gave the hinv and printenv command the following details I got
hinv
Boot PROM: Version 4.5.0, Checksum: 00970c31, Tue Feb 08 08:25:56 2005
Platform: SWBD27, Revision 3
Processor: CPU: 200 MHz PowerPC 405GP, Revision E
Primary data cache: 8 KB, 32 B lines
Primary instruction cache: 16 KB, 32 B lines
Flash memory: 16 MB x 16b @ 0xf0000000, Manufacturer ID 0x89, Device ID 0x18
Flash memory: 512 KB x 8b @ 0xfff80000, Manufacturer ID 0x1, Device ID 0x4f
PCI device: Bus 0, Slot 6, Function 0, Vendor 0x1657, Device 0x0001
Main memory: 128 MB (ECC) @ 0x00000000
        Processor Local Bus: 100 MHz
     On-chip Peripheral Bus: 50 MHz
    External Peripheral Bus: 25 MHz
    PCI Bus: 33 MHz (internal arbiter) (synchronous)
> printenv
ENET_MAC=00051E34D01F
ENET_src=10.1.1.50
LoadIdentifiers=Manually selected OS
Loadidentifiers=Fabric Operating System;Fabric Operating System
OSBooted=MEM()0xF0000000
OSLoadOptions=quiet;quiet
OSLoader=MEM()0xF0000000;MEM()0xFFF80000
OSRootPartition=hda1;hda2
What should I do to resolve the problem ? Any help would be appreacited.
Thanks in Advance.
Regards,
R.Rajesh.
Anonymous
Re: Brocade Switch 3250 not booting
Hi R.Rajesh,
I'd try and boot from alternative location, choosing "3" in the menu and then typing this at the > prompt, to start with:
> boot MEM()0xFFF80000
You might also want to tweak values in both OSLoader and OSRootPartition.
Let me know how it goes.
Linar
Anonymous
Hi Linar,
I tried in both the ways what you have given. but no success.
Any other configuration.
Any other  way to upload the FAB OS in the flash memory of the Brocade Switch.
Regards,
R.Rajesh.
