Anonymous
Brocade Silkworm 4020 reboots after 6.1.1d firmware upgrade
Hi all,
We have two Brocade Silkworm 4020 switches installed into our IBM BladeCenter H chassis. We have configured them in Access Gateway mode and we've tried to update one of this switches firmware from 5.3.0a version to 6.1.1d passing through 6.0.1a version, as required by Brocade official documentation.
The result is that if we try to access to the "Admin Port" through "Web Tools" and change any port configuration, Web Tools hangs about 3 minutes and finally shows the error message "Can't post data to the switch" (or similar) and then appears a Web Tools "Invalid Session" message
Any idea?
Thanx in advance!
Anonymous
Re: Brocade Silkworm 4020 reboots after 6.1.1d firmware upgrade
Hi again,
Problem solved.
Thanks for your collaboration
Anonymous
Hi,
Thanks for this thread. I got question as we are going to upgrade firmware at Blade, Brocade Silkworm 4020 as well:
Are there any URLs where 4020 switch command line guide could be located?
Thanks,
External Moderator
CLI guide are available for download here in the Communty.
go to
-> documentation
-> Product Manuals
-> Documentation
Select Fabric Operating System ( Fabric OS )
TechHelp24
