Anonymous
Brocade Silkworm 3000 (MSA 2/8) Switch - Flash Write Error
Hi !
Our MSA Switch went balistic yesterday, and after searching through every corner of the Internet ill ask for an answer here.
The error:
flashBlockErase: timeout at 0xc0000000, csr = 0xff7f
flashWrite: failed - retrying
flashWrite: giving up
Keeps running in the telnet console and eventually starts over again. Access via web is not possible (it times out)
The simple question is... do I dare reboot it ?
And should i try flashing it with a never fw when it hopefully boots up again?
Regards Jan
External Moderator
Re: Brocade Silkworm 3000 (MSA 2/8) Switch - Flash Write Error
Jan,
the error soudn not good.
Can you connect trough telnet ? if yes, and the CLI is work, cann you collect whit "erroshow" the error output ?
--->>> And should i try flashing it with a never fw when it hopefully boots up again?
what is the actually FabOS rel. loaded ?
--->>> ... do I dare reboot it ?
Good question, but you not have other way.....
TechHelp24
TechHelp24
Anonymous
errshow:
Error 12
0x11d69cd0 (unknown): May 26 08:18:31 (999)
WARNING FLASH-BAD_MIRROR, 3, Recovered 0 from 1: 258 bytes at 0x8
Error 10
0x11e448a0 (tMSd): May 21 12:56:28 (999)
Error 08
0x11e448a0 (tMSd): May 21 12:43:47 (9)
Error 06
0x11d9b0a0 (unknown): May 21 12:39:55 (3)
Error 04
0x11dc3210 (tEMBsw): Apr 23 01:34:39 (999)
Fabric O/S 3.2.1b
External Moderator
Jan,
you wrote:
--->>> Our MSA Switch went balistic yesterday,......
i note in the error show output, that the error is caused since April, is correct or is the Date/Time wrong set in the switch ?
I know similary error by Hardware Problem, and it's appear here that the Switch have a Corrupted Flash Bank 0.
I would proceed in this case as follow, first reboot the switch, if this reboot succesfully, than Upgrade the FOS, problable that here is the FOS Corrupted...
....w/o any warranty
the latest rel. is 3.2.1c
TechHelp24
TechHelp24
Anonymous
The error most probably exsisted for some time, but do not interfere with production.
However we where about to make some changes and realised it was defect.
So what i read from your post, then you suspect a corrupted O/S over a hardware failure ?
Regards Jan
External Moderator
--->>> but do not interfere with production
correct, because the switch have 2 Bank's, Active/Standby if any from both is corrupted the other operate whitout interrupition.
--->>>....then you suspect a corrupted O/S..
yes, but I do not want to exclude a hardware defectively
TechHelp24
TechHelp24
