Anonymous
Brocade SW300 - replacement
Hi all,
I'm new to SAN technology especially with fabric OS.
Here is my problem. We have two SAN switches sw300 with all the configuration running properly.
A week ago we get an alert for a faulty fan so we order a new switch. We also received some new license for the new switch.
We plug the new switch create all zoning from scratch (we didn't use configdownload because fabric OS is not the same with the old one).
It worked fine for about an hour and the ports change to no_sync. We plug the old switch (the one with the faulty fan) everything is ok (exept the fan )
They send  us another switch we create the zones but we do not see the alias names on the gui only the WWNs. The switch works fine but we get a warning on our RPAs complaining that some partitions use single path (all partitions, disk arrays, RPAs are connected on two switches for redundancy).
The only problem i can think of is the fabric OS firmware. Maybe they are not compatible.
The fabric OS version of the first two switches that worked fine are both V6.1.1a
now we have one switch with fabric OS V6.1.1a and the new one with V6.3.1a. From the compatibility list i cannot see any problems between these two versions. I read that V6.1.1a has a lot of bugs and i should upgrade but i don't want to risk it since we do not have multipath due to our problem.
Can you please advice me on how to proceed? Is it because of the versions OR something else you can help me with?
Thank you.
Anonymous
Re: Brocade SW300 - replacement
Hi antonis
Did you check the domain ids of your switches ? sounds like there could be a issues with domain id mis matches hence your ports going into a funky state.
Running different versions of fabric OS should not cause these types of issues , its best practice to have all the same OS level's but it won't hurt having some versions slightly different.
BTW you should not need to recreate your alias/zones from scratch , that should all flow down from your other switch in the fabric.
Regards
David
Anonymous
Hi David,
Thanks for your reply.
Sorry if i didn't explain my topology correctly. The switches are not in the same fabric. They are totally indepented paths. On each switch we have connected one of the two HBAs of each server,  same for the RPAs and the SPs of the disk array. This way all servers can access the disks from two indepented paths. In such a topology we do not have to worry about domainID (is that correct? Does it matter if the domain IDs are the same or not?).
switchshow:
/fabos/bin/switchshow:
switchName:     fabric1
switchType:     71.2
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   1
switchId:  fffc01
switchWwn: 10:00:00:05:33:17:06:50
zoning:         ON (CFG_SWITCH_23)
switchBeacon:   OFF
Index Port Address Media Speed State     Proto
  0   0   011700   id    N4   No_Light    FC
  1   1   011500   id    N4   No_Light    FC
  2   2   011300   id    N2   Online      FC  F-Port  50:06:01:69:30:20:92:e8
  3   3   011100   id    N2   Online      FC  F-Port  50:06:01:61:30:20:92:e8
  4   4   011600   id    N4   No_Light    FC
  5   5   011400   id    N4   No_Light    FC
  6   6   011200   id    N4   No_Light    FC
  7   7   011000   id    N4   No_Light    FC
  8   8   010f00   id    N4   Online      FC  F-Port  50:01:24:82:01:ab:a0:92
  9   9   010d00   id    N4   Online      FC  F-Port  50:01:24:82:01:ab:cb:8a
10  10   010b00   id    N4   No_Light    FC
11  11   010900   id    N4   No_Light    FC
12  12   010e00   id    N4   Online      FC  F-Port  50:01:24:82:01:ab:38:92
13  13   010c00   id    N4   Online      FC  F-Port  50:01:24:82:01:ab:21:8a
14  14   010a00   id    N4   No_Light    FC
15  15   010800   id    N4   No_Light    FC
16  16   010700   id    N2   Online      FC  F-Port  10:00:00:00:c9:46:92:05
17  17   010500   id    N2   Online      FC  F-Port  10:00:00:00:c9:4e:39:2a
18  18   010300   id    N2   Online      FC  F-Port  10:00:00:00:c9:4f:29:ad
19  19   010100   id    N4   No_Light    FC
20  20   010600   id    N4   No_Light    FC
21  21   010400   id    N2   Online      FC  F-Port  10:00:00:00:c9:4e:49:75
22  22   010200   id    N2   Online      FC  F-Port  10:00:00:00:c9:46:3c:b1
23  23   010000   id    N2   Online      FC  F-Port  10:00:00:00:c9:45:01:48
Sorry if i'm not very clear with my discription but my kwnolege on this subject are limited.
Thanks again.
Anonymous
If your servers are old AIX servers then you have to run the rmdev on the failed path devices and recreate the devices.
Some AIX versions stored the local SAN port IDs and the storage port IDs. If you change the DomainID of a switch it will not find the old way and the pathes are declared as dead. AIX is capable of dynamic path tracking.
Regards,
Andreas
Anonymous
Hello Andreas,
Thanks for your help. You where absolutely right!!!  The problem was on the hosts (AIX) and not on the switch. We tried cfgmgr and the paths came up alive. We also reboot the servers and the warnings were gone.
Thanks again. I appreciate your help.
Regards
Antonis Marcou
