Occasional Contributor
Accepted Solution
Brocade FCIP interconnect with Cisco MDS 9506 MSM Module
Hi,
We have Brocade DCX8510 with FX8-24 Blade in one DC and in the other DC, Cisco MDS 9506 with MSM Module to provide FCIP between DCs.
I just wanted to know how to configure FCIP between these tow devices.
Regards
Broadcom Moderator
Re: Brocade FCIP interconnect with Cisco MDS 9506 MSM Module
[ Edited ]
Hello,
As far I know this is not a supported configuration.
Just to be sure about what you would like to do:
DCX/FX8-24-----MDS 9506
DC1----------------DC2
or
DCX/FX8-24----MDS 9506----MDS 9506-----DCX/FX8-24
DC1---------------DC1------------DC2-------------DC2
Hi thierry,
thank you for your reply,
my case is the first one,
Broadcom Moderator
So not supported.
[ Edited ]
ok,
so which solution can help me to use current equipments for FCIP Intersite connectivity?
should I buy some new equipments, such as brocade 7840 on MDS side as router?
I mean this topology:
DCX [DC1] <------------> [DC2] 7840 -------- MDS9506
Broadcom Moderator
Yes a 7840 will be fine for discuss with DCX.
Cisco MDS9506 will be not able to communicate in switch mode. Device will need to run in Access gateway mode.
Concerning your complete architecture, perhaps it will be good to have your OEM involved for verify your complete need and design the best solution.
Thank you and greatly appreciate your helps and solution.
Regards
