Occasional Contributor
Brocade DCX 8510-8 FOS 7.4.1b temperature high on sensor ID 31 and 35
Hi All,
Brocade DCX 8510-8 FOS 7.4.1b  temperature high on sensor ID  31 and 35  .
is there any way to set  the threshold alert/email alert  in switch using maps or BNA ?
sensor 31: (Temperature) is Ok, value is 54 C
sensor 32: (Temperature) is Ok, value is 49 C
sensor 33: (Temperature) is Ok, value is 46 C
sensor 34: (Temperature) is Ok, value is 31 C
sensor 35: (Temperature) is Ok, value is 54 C
External Moderator
Re: Brocade DCX 8510-8 FOS 7.4.1b temperature high on sensor ID 31 and 35
@rdprrao
see in MAPS Admin Guide for BAD_TEMP, you can set as Marginal or Critical
keep in mind, temperature can may vary depend of type of Blade, but accordly your output temp is in range.
TechHelp24
@Antonio Bongiorno TechHelp24
Thanks , yes as of now temparature is normal if temparature is reached 69C only we got alert .
is there any way to set alert when the temparature will reach the value is  60C?
