Anonymous
Brocade-Cisco connection info
Hi,
to connect 1 switch Brocade to 1 switch Cisco (MDS), which kind of Brocade license I've to buy?
Fabric license, for example?
Anonymous
Re: Brocade-Cisco connection info
Depends.
If Brocade is setup as AG a fabric license in not needed.
If you should ISL the switches (Cicso in the right mode) you do need a license..
Anonymous
Tks.
What daes it means AG?....Maybe gateway mode?
Anonymous
Ag is indeed Acces Gateway
