External Moderator
Brocade 8000 enable IDLE timeout in cmsh mode
In FOS Native mode, we know the command "timeout" to set IDLE mode = timevalue or 0 to disable login timeout.
try to find for the same or equivalent command when the switch is set in "cmsh" mode, but I've no luck to find one how to disable this annoying connection timeout.
TechHelp24
External Moderator
Re: Brocade 8000 enable IDLE timeout in cmsh mode
Thanks i found the solution.
in config mode both, line console and line vty can be set to 0
TechHelp24
