Occasional Contributor
Brocade 8000 - Upgrade Firmware
Hi all,
So I am trying to upgrade the firmware on my Brocade 8000 switch since it has not been upgraded in a very long time, and I am a little confused on the process.
The firmwareshow command shows me that my FOS version is 6.4.0. Now is it possible to upgrade to the latest firmware version directly, or do I have to upgrade the firmware one version at a time?
Also, where do I find the firmware? I have looked around on the Brocade website and on Google, but i haven't found any actual files to download to use.
Thanks,
Broadcom Moderator
Re: Brocade 8000 - Upgrade Firmware
Hello ,
Last version for Brocade 8000 is 7.2.1 ,
You can dowload the FOS  from the download area of the MyBrocade site  :
https://login.brocade.com/?TAM_OP=login&AUTH_CODE=0x00000000&URL=%2Fwps%2Fmyportal%2F&HOSTNAME=my.brocade.com&PROTOCOL=https
 ! : The Brocade 8000 is not supported with FOS v7.2.0 and later.
6.4.0  -> 7.0.x -> 7.1.2
Regards
Jerome
If my response has solved your query please click the "Accept as Solution" button.
Any and all information provided by me is not reviewed, approved or endorsed by Brocade and is provided
solely as a convenience for Brocade customers. All systems and all networks are different and unique. If
you have a service affecting network problem, please open a TAC service request for service through
Brocade, or through  your OEM equipment provider.
