Anonymous
Brocade 7800 Ethernet negotiation speed - 1Gbps only?
Hi,
Can the extension Ethernet ports on the Brocade 7800 negotiate down to 100 Mbps?  Have heard this might not be possible, but seems odd....
Thanks!
--HRL
Anonymous
Re: Brocade 7800 Ethernet negotiation speed - 1Gbps only?
No,
It is not possible because these are GbE ports. and btw why are you trying ot do so?Even if you try you wil not get the result
