Anonymous
Brocade 7800 Downgrade Problem
HI,
I have 2 Brocade 7800 SAN routers, They had version v6.3.2b.
I upgraded to version v6.4.1a and I noticed that I had some problems with older models (Brocade 3900).
In version v6.3.2b everthing was working fine and now I need to downgrade back to v6.3.2b but I'm always getting this error:
Checking system settings for firmwaredownload...
Failed to access ftp://hugo:*************************@172.31.1.229/v6.3.2b/release.plist
The server is inaccessible or firmware path is invalid. Please make sure the server name or IP address, the user/password and the firmware path are valid.
I'm sure I'm doing everything correctly, I have done a lot of upgrades and downgrades.
The FTP server is up and running.
The folder contents are good. (I have done other upgrades from that folder)
The name I insert is correct. I tried v6.3.2b and just in case v6.3.2b/release.plist
Any help with this would be apreciated has I'm stuck at this point
Thank you
Hugo
Anonymous
Re: Brocade 7800 Downgrade Problem
I'm sorry someone had block FTP in my router so the switch could not access the FTP for the firmware Downgrade.
