Occasional Visitor
Accepted Solution
Brocade 6510 with 8GB SFP+ GBIC running at 2GB
Hello,
I've got a 6510 (with 16GB GBIC's) and need to connect a couple of old servers running 2GB. According to the Brocade Fibre Channel Transceiver Support Matrix, the following part:
57-1000117-01/XBR-000163 is compatible with the Brocade 6510.
Can anyone confirm if the XBR-000163 will actually drop down to  2GB and do so in a 6510?
Thanks,
Phil.
Regular Contributor
Re: Brocade 6510 with 8GB SFP+ GBIC running at 2GB
Hi Phil,
this SFP+ can be used in GEN5 switches (also in 6510).
It supports 2,4 and 8G FC speed.
Kind Regards
Ralf
