Anonymous
Brocade 5000 vs McData 4700 ISL problems
Hi all
I faced a critical issue on ISL between Brocade 5000 and McData 4700
The background as below
McData 4700 firmware 9.3.1, Domain ID#1 , interop Mode :1 (Existing switch with zoning)
Brocade 5000 firmware :5.3.X, Domain ID#99, Interop Mode: 1 (Fresh install)
A Fiber was plugged between two switch
Both of their connection ports were shown as E-Port
In Brocade 5000 web GUI, i can see two switches (Domain ID #97 & #99)
Since the Domain #97 is equal to McData Domain #1
1)
The switch with Domain#97 cannot be extended when i double click, that
means i cannot see the port of McData in Brocade Web GUI.
2) None zoning from McData can be seen on Brocade Web GUI, but all WWN from McData can be found.
3) The Zone Config of McData cannot be found on Brocade.
4) In case, i enter the brocade via TELNET. All zoning of McData can be seen by typing "zoneshow"..
In McData Web GUI.
It shows the McData port only, no port of Brocade 5000 can be found
i wonder why i can;t find the zoning on web GUI but on telnet. Is the ISL procedure incomplete.?
Anyone faced the similar issue?
Thank you very much
External Moderator
Re: Brocade 5000 vs McData 4700 ISL problems
maxchun,
--->>> 1)
Is correct, you cannot admin the McDATA from a Brocade Webtool and viceversa, you cannot Admin the Brocade from the EFCM Basic, because both Switch have a Different GUI.
--->>> 2) None zoning from McData can be seen on Brocade Web GUI, but all WWN from McData can be found.
--->>> 3) The Zone Config of McData cannot be found on Brocade.
Log into the 4700 trough a GUI, -> Logs ->Event, and see if you have a Error Code, if yes what is the Error Code ?
I assume the Code is 81 or 081.
--->>> .....Is the ISL procedure incomplete.?
Probable no, the reason is a Security mismatch beetwen Brocade/McDATA
TechHelp24
TechHelp24
Anonymous
1) Since the site is not ready now, we can't check the log error
If there is Code 81, how can i treat it well?
2)How to config the security properly to fit the isl ?
Btw, do i need to set the brocade 5000 to principal mode ? it is in bordinate mode during fail
thank you
External Moderator
Hi null,
in order to avoid confusion, are you the same here as maxchun ?
--->>> Btw, do i need to set the brocade 5000 to principal mode ? it is in bordinate mode during fail
No, Principal and/or Subordinate dont solve the Problem.
--->>> ....If there is Code 81, how can i treat it well?
This is a critical point by McDATA, you must first disable the Option "Safe Zoning Mode"
Check trough the GUI, ->Security -> Safe Zone Mode, is this enable or disable ?
TechHelp24
TechHelp24
Anonymous
Hi Support,
--->>> 1)
Then, if the ISL is done but how can I make a zoning between McDATA to Brocade?
-->2) At Brocade GUI side, we can see the all port information(WWN) from McDATA but nothing Alias and zone config can be found. At McDATA side can't see anything from Brocade and just have a second switch and it is dim.
-->3)Then I try from Brocade CLI with "zoneshow" and "switchshow" command, that can be see the zoning from McDATA. Then I try to save the config but it wouldn't be save.
Also attached the McDATA switch config, the safe zone is disabled
Switch Information
State: Online
R_A_TOV: 100
E_D_TOV: 20
Preferred Domain ID: 1
Domain ID Offset: 96
Switch Priority: Default
Rerouting Delay: Disabled
Interop Mode: Open Fabric 1.0
Active Domain ID: 1
World Wide Name: 10:00:08:00:88:E3:32:20
Insistent Domain ID: Disabled
Domain RSCN: Disabled
Zoning RSCN: Enabled
FC Address Domain: 61 (hex)
Limited Fabric RSCN: Disabled
Zone FlexPars: Fabric Filtering
RSCN Zone Isolation: Fabric Filtering
Safe Zoning: Disabled
ISL FSPF Cost: By Port Speed
Web Enabled: Enabled
API Enabled: Enabled
API Management IP: 196.69.108.11
Password Exp. Time: 0
Thanks!
External Moderator
Gallons,
I assume you are the third here, correct?
You write:
--->>> Hi Support,
Please note, this is not a Commercial Brocade Support, this is a Community Board. If you need a Support must Buy a Support Contract by Brocade.
TechHelp24
Anonymous
hi
there is no event log 81
and the safe zoning is already disabled.
any ideas on it ?
since the interop mode is supported mcdata 9.x vs brocade 5.3.0
safe zoning disable
domain 1 vs domain 99
open fabric 1 vs interop mode 1
