Anonymous
Brocade 5000 switch serial connection
Hi all,
I am trying to connect a retired DS5000 switch to set factory default and IP to bring it online. When I try to connect through hyperterminal/putty with 9600,8,1,None,XON/XOFF/None ..., I am getting continuous ASCII characters scrolling out and I need to close the terminal to stop it.  How can intrepret and stop the scrolling and get a readable output OR how can I get a command prompt. Any help would be much appreciated..
Anonymous
Re: Brocade 5000 switch serial connection
Hi!
Did you try with 9600/8/N/1/None... it's the standard configuration for Brocade switches.
Regards.
Javier.
Anonymous
problem resolved after using rj45 serial cable. Thanks
