Anonymous
Brocade 4900 upgrade issue
Hi,
I get the following error when upgrading Broacde 4900 switch:
BTL_FCA_COR:admin> firmwaredownload
Server Name or IP Address: 10.160.41.173
FTP User Name: ponnappa
File Name: /home/ponnappa/v5.3.1a
FTP Password:
Verifying the input parameters ...
Checking system settings for firmwaredownload...
: command not found
: not a signal specification
: command not found
: command not found
: command not found
: command not found
: command not found
'tmp/preinst: line 176: syntax error near unexpected token `otherhost(){
'tmp/preinst: line 176: `otherhost(){
The current firmware is :
Kernel:     2.4.19
Fabric OS:  v5.2.0a
Made on:    Thu Oct 5 21:12:22 2006
Flash:      Tue Mar 13 11:17:12 2007
BootProm:   4.5.3
Any help i smuch appreciated.
Rgds,
Ponnappa
Super Contributor
Re: Brocade 4900 upgrade issue
FTP must in the same IP range as the switch.
the FTP server must be pointed to: /home/ponnappa
the correct file name in order to start a upgrade procedure is: /v5.3.1a/release.plist
Anonymous
Hi, If you are using widows version then type file name through \ slash. Also pls check FTP server is properly accessible. If you will face issue. connect the console cable and do it from laptop
Anonymous
Thanks to ABBA and Hemant replies.
Heres what I did.
1. FTP server does not have to be in the same subnet as the switch. It just needs to be accessible over lan without a firewall.
2. I copied the firmware folder to my home directory ;ie;/home/ponnappa/v5.3.1a. By default FTP directory point to my home directory upon my login.
3. BTL_FCA_COR:admin> firmwaredownload
     File Name: v5.3.1a
     FTP Password:
     You can run firmwaredownloadstatus to get the status
     of this command.
     ....and finally the installation completed successfully.
Rgds,
Ponnappa
