Contributor
Brocade 48000 HA errors following CP blade swap.
Hey,
We recently had a CP blade swapped out and now have the following config:
Slot Name       Appl     Primary/Secondary Versions               Status
  5  CP0        FOS      v6.3.1a                                  STANDBY
                         v6.3.1a
  6  CP1        FOS      v6.4.3                                   ACTIVE *
                         v6.4.3
We are seeing loads of these:
2012/12/14-10:34:21, , 50590, SLOT 5 | CHASSIS, WARNING, RELN_PRO_SAN002, Component (swc) dropping HA data update (6291467).
Type <CR> to continue, Q<CR> to stop:
2012/12/14-10:34:21, , 50589, SLOT 5 | CHASSIS, WARNING, RELN_PRO_SAN002, Component (swc) dropping HA data update (5242890).
I assume this is caused by the inconsistent firmware - can someone confirm this?
External Moderator
Re: Brocade 48000 HA errors following CP blade swap.
will,
connet to the standby CP slot 5, and start upgrade FOS v6.4.3 with command/operands
"firmwaredownload -s"
-s operand force the upgrade only on single CP blade.
I you have more questions, let me know.
TechHelp24
