Anonymous
Brocade 4800 FR4-18i blade
I have Brocade 48000 chassis. We recently bought FR4-18i blade. When I put it in the chassis I have these messages: 2007/04/04-20:46:20, , 119,, INFO, SilkWorm48000, FRU Slot 4 insertion detected.2007/04/04-20:46:20, , 120,, WARNING, SilkWorm48000, Sysctrl reports error status for blade ID 20 for the blade in slot 42007/04/04-20:46:20, , 121, FFDC, CRITICAL, SilkWorm48000, Unit in Slot 4 faulted, incompatible with chassis option 5----
External Moderator
Re: Brocade 4800 FR4-18i blade
Hi Vitocapri,NOTE! EM-1046 indicate the Header this Blade is Corrupted and the blade must be replaced!
TechHelp24
External Moderator
I just note follow,Are they Sure that the ID show is 20 ? Can you confirm ?
TechHelp24
Anonymous
Thank you for quick answer. Yes, it shows up as ID 20. Looks like blade indeed bad.
External Moderator
OK, have the Blade 16 Port and Additional One Console Port and One Ethernet Port ? Or can you Upload here a PIC this Blade ?And the Exact Brocade Part Number is Label on Board ?
TechHelp24
Anonymous
I see this info: D1846, 40-0300108-01 Rev.A, D1858, barcode with MN030000152.Thank you
External Moderator
Hi Vitocapri,Problem is Solved !
TechHelp24
External Moderator
To confirm my last Answer, i found in Google a PIC this Blade. Is this the Same Blade you have ?See attach.
TechHelp24
Anonymous
Thanks a lot! Will contact our vendor.
External Moderator
-&gt;&gt;&gt; Thanks a lot! <BR><BR>No Problem. <img src="http://boards.brocadeconnect.com/groupee_common/emoticons/icon_wink.gif" alt="Wink" width="15" height="15">&lt;!graemlin:;)&gt;<BR><BR>-&gt;&gt;&gt; Will contact our vendor....and many greating to you Vendor.
TechHelp24
