Anonymous
Brocade 4/24 SAN Switch for HP c-Class BladeSystem password reset
Hello All,
I need help with password reset for Brocade 4/24 SAN Switch for HP c-Class BladeSystem.
I don't have root, admin or any other password but I need to reset it.
Any help appreciated.!
Thanks in advance
Wojciech
Anonymous
Re: Brocade 4/24 SAN Switch for HP c-Class BladeSystem password reset
Hi wojciech.marusiak,
= is that switch connected to any other switch?
= what FOS version they run?
Anonymous
Hello Linar,
this switch is inside of Blade enclosure. I can connect to second switch (same model and most likely same FOS version) with default username and password.
FOS (I guess this is firmware version of switch) is v5.3.1a
Anonymous
if you can make this switch part of a fabric were passwords are known, resetting passwords is easy.
Contact me offline for step-by-step instructions.
Linar
Anonymous
Why offline? That doesn't help the community.
If my guessing correctly you want,
-to merge the switches in a fabric with known uid/pwd combo
-execute a distribute -p PWD (-d for a list perhaps) on the switch with known pwd/uid combo's to push the pwd to all or listed switches.
Anonymous
Hi dion.v.d.c,
your guess is correct but the tricky part here is to temorary merge two 4/24s while preserving both fabric's zone configurations.
Linar
