Contributor
Brocade 300 problem sfp module ( Speed Missmatch incompatible sfp)
I have the Brocade 300 as you can see on the pictures but I have problem when I connect the fiber. See evidence
http://sia1.subirimagenes.net/img/2015/02/04/150204114008564343.png
http://sia1.subirimagenes.net/img/2015/02/04/150204114009134553.png
http://sia1.subirimagenes.net/img/2015/02/04/150204114010533522.png
Hpw should I face this problem??
Thanks!!
Occasional Contributor
Re: Brocade 300 problem sfp module ( Speed Missmatch incompatible sfp)
Hi,
looks like incompatible SFPs. Beginning with the 8Gbps switches only Brocade certified SFPs are supported in a Brocade switch. This is to make sure to keep the Brocade specifications. Make sure you have Brocade supported SFPs. I belive there is a list somewhere on the Brocade web site, but all major Brocade OEMs (HP, EMC, etc...) have them too.
Valued Contributor
Hi there,
@holger.fitz is completely right, when it comes to 8G, you can only use Brocade branded SFPs....
Rgds,
Felipon
