Anonymous
Brocade 300 not merge fabric with Brocade 4/24 SAN Switch for HP c-Class (type 43.2)
hi,
I have an existing fabric with two Brocade 4/24 SAN Switch for HP c-Class (type 43.2) I want to add a new Brocade 300 but when i link together show this error
brocade 300 (FOS v7.0.0a)
B300:admin> switchshow
switchName:     B300
switchType:     71.2
switchState:    Online
switchMode:     Native
switchRole:     Principal
switchDomain:   5
switchId:       fffc05
switchWwn:      10:00:00:05:33:69:c8:b5
AD Feature:     Active
Current AD:     0
zoning:         OFF
switchBeacon:   OFF
Index Port Address Media Speed State     Proto
   0   0   050000   id     N8   No_Light    FC
   1   1   050100   id     N4   Online      FC  E-Port  segmented,(zone conflict)(Trunk master)
HP 4/24 (FOS v6.2.0b)
SWHP:admin> switchshow
switchName:     SWHP
switchType:     43.2
switchState:    Online
switchMode:     Native
switchRole:     Subordinate
switchDomain:   2
switchId:       fffc02
switchWwn:      10:00:00:05:1e:06:3a:d3
zoning:         ON (FABRIC_TEST)
switchBeacon:   OFF
Area Port Media Speed State     Proto
21  21   id    N4   Online           E-Port  segmented,(zone conflict)(Trunk master)
before I try to merge I :
disable  B300 switchdisable
clearcfg
configure (Domain ID 1 in this way fabric assign new Domain ID 5)
switchenable
I upgrade FOS in SWHP in the other switch to v6.2.2e and nothing change
thanks in advance for any hints
regards
Anonymous
Re: Brocade 300 not merge fabric with Brocade 4/24 SAN Switch for HP c-Class (type 43.2)
The zoning config on both switches do not match.
That could point to
-effective config is different between the two
-defzone is set to no access while no zoning is ineffect.
-names of object are used differently in both configs
-or content and or order of oject is different.
My guess atm is defzone troubles.
Could you do a defzone --show on the B300?
Anonymous
on B300
defzone --show
Default Zone Access Mode of AD0
          committed - No Access
          transaction - No Transaction
on HP 4/24
defzone --show
          committed - All Access
Anonymous
A noaccess defzone has hidden zones and aliases.
Nothing fancy just a dummy alias an dummy zone which are in affect to exclude the rest of the world.
But even that hidden config will induce an zoning conflict if you try to merge.
Can you execute a defzone --allaccess on the B300 en try your merge again?
Anonymous
actually I try and show me this message
defzone --allaccess
Operation allowed only in AD0 context adn if no ADs are configured
Anonymous
So questions are
-are you in using AD's? > ad--show
-and are you in AD0 context? > ad --select 0
Anonymous
And to add to that, wheter you intend to use AD's or not read the fosadmin guide on this subject. It can aid you to configure (or deactivate) AD to way you want or need it.
Anonymous
ad --show
Current AD Number: 0  AD Name: AD0
Effective configuration:
AD Number:   0  AD Name: AD0    State: Active
        Switch port members:            12,0; 12,1; 12,2;
after publish this I also try with the command
ad --show -i
AD: 0 :         AD0     Active
        Switch port members:            5,23; 5,22; 5,21; 5,20; 5,19;
                                        5,18; 5,17; 5,16; 5,15; 5,14;
                                        5,13; 5,12; 5,11; 5,10; 5,9;
                                        5,8; 5,7; 5,6; 5,5; 5,4; 5,3;
                                        5,2; 5,1; 5,0;
now I see that the correct domain ID ( 5) is displayed to reference switch ports members, why in the other way is displayed 12 instead 5 ??
Anonymous
OK I haven't worked that much with active AD's but
Looks like AD0 has port 0 thru 2 from domain 12 as members.
Wether this is correct I do not know. Do or did you have an switch with DiD 12?
At least it shows the default AD0 and no others.
You could try a
switch:admin> ad --select AD0
switch:admin> defzone --allaccess
switch:admin> cfgsave
And them try to merge you B300 into your existing fabric.
Anonymous
before be able to do defzones --allaccess first I should go and clear all existing configuration on AD0, after this with defzones and other stuffs the 300 merge thks X everthing
