Anonymous
Brocade 300 lost configuration during firmware upgrade
Hello,
During firmware upgrade from v6.3.1b to v6.4.1b of Brocade 300 lost configuration and there was a few minutes of traffic lost.
I did configdownload and seems everything ok (checked with fabricshow and zoneshow), but I'm not sure because I'm new with SAN.
Is there a way to see in logs reason for this config lost?
How can I make sure that config is properly downloaded?
Thanks.
Regards,
Marko
Valued Contributor
Re: Brocade 300 lost configuration during firmware upgrade
try errdump -a to see if  the switch reported any kind of issue during the upgrade.
An easy way to check if config was applied with success is performing a new configupload and compare the current config file and the one you applied.
