Anonymous
Brocade 300 SAN switch port fluctuation problem
my brocade 300 SAN switch ports are keep fluctuating...when i transfer the data between server to storage device the speed is keep on varying..port status speed keep on varying...
Please guide me to troubleshoot the above problem.
Frequent Contributor
Re: Brocade 300 SAN switch port fluctuation problem
Hi ,
I have moved your discussion thread to the Data Center SAN Forum as that will be the best place to get your question answered.
Thank you for using Brocade Communities!
Cheers,
Grace Chang
Global Community Manager
Valued Contributor
Hi,
Could you be more accurate in the description of your problem? What do you mean by port fluctuation, that the port speed is changing, e.g., from 4G to 8G? or that throughput is continuously changing.
Please, describe your environment for us: how may HBAs, does the host has? how many switchs? etc.
How do you measure these fluctuations?
Kind regards
