Anonymous
Brocade 300 - ISL - initital setup problem
I'm trying to connect two Brocade 300s, recently upgraded to Fabric OS:  v6.4.2a.
I installed 30km lw sfps in both switches, ports 9:
Vendor Name: BROCADE
Vendor PN:   57-1000020-01
And connected the ports.  Currently the switches are located in the same rack; I'm just trying to confirm they work and can be ISL'd.
switchshow shows:
9   9   020900   id    N4   In_Sync     FC
and
9   9   010900   id    N4   In_Sync     FC
I'm sure it's something simple.
Is there a minimum distance needed for the ISL long wave to be valid?
Do I need an extended fabric license to use these 30km sfps?  Even thought at the moment the distance is only a few feet?
What cable type should I use?  Multi vs. single mode?
Anonymous
Re: Brocade 300 - ISL - initital setup problem
Are you using single mode optical cables to connect both switches?
Do you have extended fabric license to support the 30 km distance?
Anonymous
I switched to SM (single mode) cables and the ISL is working ok.
Outstanding!
9   9   870900   id    N4   Online      FC  E-Port  10:00:00:05:1e:bd:15:40 "ea-san-sw2" (upstream)
9   9   880900   id    N4   Online      FC  E-Port  10:00:00:05:1e:c5:76:29 "ea-san-sw1" (downstream)
