Anonymous
BR425 and TS3200 Tape library
I attached BR425 HBA o the IBM3650 M2 server. And attached HBA to the TS3200 Tape Library. From Boot Menu we can not see any tape library. We check firware version of the tape library. It is last update.
What should be checklist to recognize the problem.
Thanks for any helps.
Anonymous
Re: BR425 and TS3200 Tape library
Tape drive is ULT3580-TD4
External Moderator
The TS3200 tape Library consist as Device with FC Port and is designed to Connect in a existing SAN environments, SAN Switches.
You cannot connect the the device Direct to any in Server fit HBA.
TechHelp24
Anonymous
Hi
I handled problem with using another vendor HBA. Thanks for help.
