Contributor
BR-310 Port No_Sync problem
Hi,
I have a BR-310 switch,Version v6.2.0c,  connect device, switchshow output display:
switchshow:
switchName: swd77
switchType: 71.2
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:05:1e:c4:4d:9b
zoning:  OFF
switchBeacon: OFF
Area Port Media Speed State     Proto
  0   0   id    N4   No_Light
  1   1   id    N4   No_Light
  2   2   id    AN   No_Sync
  3   3   id    AN   No_Sync
  4   4   id    AN   No_Sync
  5   5   id    AN   No_Sync
  6   6   id    AN   No_Sync
  7   7   id    AN   No_Sync
  8   8   --    N8   No_Module        (No POD License) Disabled
FOS upgrade: v6.2.0c --v6.3.0d--b6.4.2b--v7.0.0b;
Problem is still not sloved.
Valued Contributor
Re: BR-310 Port No_Sync problem
Lucky_li, what do you connect to these ports?
No_Sync means there's some light signal but port can't sense the speed...
What do you see when you type sfpshow/portshow/porterrshow/portstatsshow?
