Anonymous
Accepted Solution
BNA switch users for fabric discovery
[ Edited ]
Hello guys,
some days ago i tried to discover some SAN Switches with the BNA (Brocade Network Advisor 12.1.x).
If i use the admin user (SAN Switch user) it works without any problems.
Then i have tried it with other users, but it didn't work. Maybe i have forgott something when i create the users?
(i have created users with all kind of permissions like admin, fabricadmin, secadmin)
I have used this command with FOS 6.4-7.2 Switches: cfguser --add <name> -r <role / permission for example admin>
Is there a possibility to discover the switches with another user as "admin" with lower permissions?
kind regards.
Regular Contributor
Re: BNA switch users for fabric discovery
The user has to have the "Chassis admin role" on the switch plus each logical switch needs to have the same switch and SNMPv3 user account on all logical switches (1 to 128)
Kind regards,
Erwin van Londen
Brocade Distinguished Architect
http://www.erwinvanlonden.net The Fibre Channel blog
Q&A -> https://hackhands.com/elo/
Anonymous
hey,
thank you for your reply and solution.
I have implemented a user with chassis admin role and it works fine.
Kind regards.
