Anonymous
BIG PROBLEM 4100/EMC2
Hello guys.
Anonymous
Re: BIG PROBLEM 4100/EMC2
Oscar,Fernando
Anonymous
hello Fernando I am spanish.Muchas gracias.
Anonymous
Oscar,Once we had a problem that a hosts didnt see the disks and we had to enable config again, then everything was fine.
Anonymous
Sorry Fernando abaout that,thanks.
Anonymous
Oscar,Fernando
Anonymous
Fernando.thanks fernando.
Anonymous
I saw this problem with an Emulex firmware version after a port disable/enable while testing. My server is down (build testing) now so I don't have access to the FW but if you're using Emulex LP9000's try an older revision of the firmware.-Chris
Anonymous
O.k guys i fix the problem.Thanks.
Anonymous
ohhh i think so that problem was fixed, but no.Thanks.
