Anonymous
BC 20-port 8Gb FC SAN Switch Module Brocade (14xInt, 6xExt) and Cisco MDS 9124 - E-Port segmented,(Eport Isolated)
It is possible to connect the MDS 9124 and BC 20-port 8Gb FC SAN Switch Module Brocade (14xInt, 6xExt). Need to traverse it with the IBM DS 3400 Storage System in 9124 on blade server is connected to the Brocade SAN switch. I have found here is a solution: I created a new VSAN on 9124, put the port, connected to Brocade into this VSAN and set interop mode 4 for this VSAN. The Brocade into interop mode 2. This works fine. But Cisco MDS 9124 doesn't support IVR (Inter-VSAN Routing), so the connected Brocade switch cannot operate with another VSAN's devices...
If to put the Brocade into AccessGateway generates this error on port - mode NPIV not supported by Fabric port...
External Moderator
Re: BC 20-port 8Gb FC SAN Switch Module Brocade (14xInt, 6xExt) and Cisco MDS 9124 - E-Port segmented,(Eport Isolated)
we discussed this at several time here in the community, please looking for similarly other threads.
Cisco should be set in Interop-Mode 3
TechHelp24
Anonymous
Cisco and brocade must be in Interop-Mode 3?
External Moderator
--->>>.....brocade must be in Interop-Mode 3?
NO! just only the Cisco must be set in IM-3, leave the Brocade in Native Mode, and enable the port as NPIV
try follow,
name-Switch-Fb-01# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
name-Switch-Fb-01(config)# interface fc 1/30 <-is a port example
name-Switch-Fb-01(config-if)# switchport fcrxbbcredit 16
name-Switch-Fb-01(config-if)# no shut
BROCADE:
Any Brocade-Switch-in-native-mode:admin> portcfgislmode 0 1 <- is a port example
Now you should see from Cisco Fabric Manager the Brocade Switch with all maintained Zoning
TechHelp24
Anonymous
On Brocade - (Segmented)(Op Mode incompat)
External Moderator
is th eBrocade on FOS 6.x or 7.x ?
FOS 7.x not longer support Interop-Mode with Cisco, in such case you can only work in AG Mode.
Post more details about the Brocade, Switch Type, FOS Release, License show etc....
TechHelp24
Anonymous
6.3.1b
8 Gig FC , Fabric , Enhanced Group Management , Full Ports on Demand license - additional 10 port upgrade,
switchName: brocade8Gb
switchType: 73.6
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 1
switchId: fffc01
switchWwn: 10:00:00:05:33:db:4c:1f
zoning: OFF
switchBeacon: OFF
Index Port Address Media Speed State Proto
  0 0 010000 id N4 Online FC E-Port segmented,(Op Mode incompa t)
  1 1 010100 cu AN No_Sync FC
  2 2 010200 cu N8 Online FC F-Port 21:00:00:24:ff:3b:4f:88
  3 3 010300 cu AN No_Sync FC
  4 4 010400 cu AN No_Sync FC
  5 5 010500 cu AN No_Sync FC
  6 6 010600 cu AN No_Sync FC
  7 7 010700 cu AN No_Sync FC
  8 8 010800 cu AN No_Sync FC
  9 9 010900 cu AN No_Sync FC
10 10 010a00 cu AN No_Sync FC
11 11 010b00 cu AN No_Sync FC
12 12 010c00 cu AN No_Sync FC
13 13 010d00 cu AN No_Sync FC
14 14 010e00 cu AN No_Sync FC
15 15 010f00 id N8 No_Light FC
16 16 011000 id N8 No_Light FC
17 17 011100 id N8 No_Light FC
18 18 011200 -- N8 No_Module FC
19 19 011300 -- N8 No_Module FC
External Moderator
what is Domain ID on Cisco ?
TechHelp24
Anonymous
fcdomain domain 1 preferred vsan 1
External Moderator
--->>>fcdomain domain 1 preferred vsan 1
It is "FUNDAMENTAL"
each switch in the Fabric, Logical VSAN, or whatever.... must have a "UNIQUE" Domain ID
with other word, you have  ID Conflict
TechHelp24
