Anonymous
After using ipAddrSet do i need to save to flash?
After using ipAddrSet do I need to save to flash or will I lose my new configuration if the power is lost?
If I need to save the new configuration to flash - what is the command for this?
I am using a Brocade with Fabric OS 6.3.0.
Thanks,
Richard.
Anonymous
Re: After using ipAddrSet do i need to save to flash?
Ipaddrset is effective immediatly and saved automaticly
With regards to your second question, it depends on what your trying to achive.
The most used command is cfgsave followed by cfgenable after altering zoning.
However there are more "save" commands, try help|grep -i save to find them all.
Anonymous
Thanks Dion, I couldn't find the answer in the help or command line reference, so that is very reassuring!
Richard.
