Anonymous
Access Gateway Connectivity Issue
Hi,
External Moderator
Re: Access Gateway Connectivity Issue
Charles,See attached RN of 5.2.3 closed defects, NPIV problem is solved by v5.3.0
TechHelp24
Anonymous
Thanks for the suggestion. I had them set to AN so I set them to 2Gb on both the 4024 and the 3850 and reenabled the ports on the 4024...unfortunately this did not work.Charles
External Moderator
Hi Charles,is this a VL= Value Line licensed ?
TechHelp24
Anonymous
Hi,Charles
External Moderator
Charles,Upgrade the 3850 to 5.3.0a must solved the problem.
TechHelp24
