New Contributor
AG mode port mapping issue: Configured_F_Ports and Current_F_Ports
Hi all,
I have one switch was configured as AG mode,
chs00122swm7:admin> switchshow
switchName:     chs00122swm7
switchType:     72.3
switchState:    Online
switchMode:     Access Gateway Mode
switchWwn:      10:00:00:05:33:3f:5c:30
switchBeacon:   OFF
Index Port Address Media Speed State     Proto
17  17   011100   id    N8   Online      FC  N-Port  10:00:00:05:1e:4f:70:00 0x301800 (Trunk port, master is Port 18 )(AoQ)
18  18   011200   id    N8   Online      FC  N-Port  10:00:00:05:1e:4f:70:00 0x301800 (Trunk master)  (AoQ)
But i have one issue, if you look at Current_F_ports, all the F-ports are mapped to N-port 18. it supposes to be F-ports 9,11,13 mapped to N-port 17. Please take a look:
chs00122swm7:admin> ag --mapshow
N_Port  Configured_F_Ports      Current_F_Ports Failover Failback PG_ID PG_Name
   0    None                    None             0       0         0    pg0
  17    1;3;5;7;9;              None             0       0         0    pg0
        11;13;14;15
  18    2;4;6;8;10;             9;10;11;12;13;   0       0         0    pg0
        12;16                   14;16
  19    None                    None             0       0         0    pg0
  20    None                    None             0       0         0    pg0
  21    None                    None             0       0         0    pg0
  22    None                    None             0       0         0    pg0
  23    None                    None             0       0         0    pg0
chs00122swm7:admin> ag --policyshow
AG Policy                        Policy Name     State
Port Grouping                    pg              Enabled
Auto Port Configuration          auto            Disabled
Advanced Device Security         ads             Disabled
WWN Based Load Balancing         wwnloadbalance          Disabled
Could someone  let me know how to move the F-port 9,11,13 to N-Port 17?
Any assistance will be greatly appreciatd!
charles
Senior Member
Re: AG mode port mapping issue: Configured_F_Ports and Current_F_Ports
If port 17 & 18 are trunked "together" (as it appears they are) then essentially they are serving together as a "combined" port. The only way to map any of the blade HBAs to port 17 would be to break the trunk and then perform the mapping. =-Marc->
