New Contributor
Accepted Solution
A simple for script not working
Hello everyone,
Can someone please help me with a simple for i script to nodefind all wwn's of a switch?
I tried this:
ssh admin@switch "for i in `cat testingscript` ; do echo $i; nodefind $i | grep -i "Aliases:"; done"
admin@switch's password:
rbash: -c: line 2: syntax error near unexpected token `1/18'
rbash: -c: line 2: `1/18 ; do echo ; nodefind | grep -i Aliases:; done'
My file looks like:
root@vgrcd1ss:/home/adel# cat testingscript
8/30
1/18
I just want to place either ports either some WWN's and see their aliases.
What am I doing wrong?
Thanks and regards,
Adel
Broadcom Moderator
Re: A simple for script not working
Hello,
Which FOS version are you using?
New Contributor
Hello Thierry,
Fabric OS: v6.3.1a
Is this the cause?
Thanks,
Adel
Broadcom Moderator
[ Edited ]
You can't use nodefind with Port number, only PID (Eg: 020100).
nsaliasshow can provide you the necessary information.
