Occasional Contributor
8Gb switches and the vc channels
ScreenHunter_01 Mar. 19 11.20.gifHi
Hello,
How to find out the mapping between the fysical switchports and his VC channel?
I have B5300 switches and would like to move the storage port to different VC channels for bottleneck issue's
It soons like : port 0 16 32 48  64 mapped to vc0
                      port 1 17 33 49  65  mapped to vc1
                      port 2 18 34 50  66  mapped to vc2
                      port 15 31 47 63 79  mapped to vc16
Regards
Ivo
Regular Contributor
Re: 8Gb switches and the vc channels
Hi Ivo,
you can not use all 16 VC Channels.
VC 0: for Class F traffic only
VC 1: Reserved
VC 2-5: for Medium Priority QoS traffic
VC 6: Class 3 multicast
VC 7: Broadcast/Multicast
VC 8+9: Low Priority QoS
VC 10-14: High Priority QoS
VC 15: Reserved
If you do not use QoS Based Traffic Prioritization you will use only VC 2 - 5 for your traffic.
Then you have only the following VC available:
VC 0: Class F traffic
VC 1: Class 2 Ack/Link Control
VC 2-5: Data Frames
VC 7: Broadcast / Multicast
It depends on the Destination Port which VC is used.
Ports with with binary value 0000 will use VC 2, with binary value 0001 will use VC 3, with binary value 0010 will use VC 4
and ports with binary value 0011 will use VC 5.
Regards
Ralf
Kind Regards
Ralf
Thanks Ralf ,
can you evaluate the vc for this litte output,
the explanation "port with bin 0000 use vc2 , dec 0001 use vc3 , dec 0010 use vc4 and dec 0011 use vc5" is not clear to me.
this means: port 0 use vc ....                    this is a dest port storage.
                    port 1 use vc ....
                    port 2 use vc ....
                    port 8 use vc ....                    this is also a dest storage
Regards
Ivo
Regular Contributor
Hi Ivo,
sorry there was a mistake in my explanation. I correct it right now.
Dest. Port 0 has binary value 0000 so it uses VC 2
Dest. Port 1 has binary value 0001 so it uses VC 3
Dest. Port 2 has binary value 0010 so it uses VC 4
Dest. Port 3 has binary value 0011 so it uses VC 5
Dest. Port 4 has binary value 0100 so it uses VC 2
Dest. Port 5 has binary value 0101 so it uses VC 3
Dest. Port 6 has binary value 0110 so it uses VC 4
Dest. Port 7 has binary value 0111 so it uses VC 5
Dest. Port 8 has binary value 1000 so it uses VC 2
Dest. Port 9 has binary value 1001 so it uses VC 3
and so on...
Sorry for the problem in my first explanation.
Regards Ralf
Kind Regards
Ralf
